I guess like any other brake system, bleed the caliper farthest away from the master cylinder and work your way "in".
Is there a specific reason you need to bleed your brakes ?
the BOOK says to change the brake fluid at 28,000 miles from what I'm told....
i have 45,000 miles of smiles on mine, so i guess i'm over-due... :lecturef_smilie:
dp
To avoid air bubbles use a pressure bleeder
OK, tomorrow i bleed the brake system on my 2015 F3 for the 1st time....
I'm of the opinion that the sequence for bleeding is: rear, left front and lastly the right front caliper.... am i correct...?
anyone have any additional tips....
thanx in advance....
Dan P
SPYD3R
My 2012 RT calls for a fluid change at 14,500 or 2 years which ever comes first. I had mine done at 14,500 and it was actually 4 years. The fluid looked really bad. I had it done by the dealer that time but will try it myself next time which will be this spring when the world warms back up. I am pushing 36,000 miles and it is coming up on 2 years. BTW I don't like the brakes on the 2012,they always feel mushy but I have had them bled twice with no change.
Using Buds to bleed the VCM would be a more complete job, but skipping that part will only leave a small amount of old fluid in the system. I skipped that part.
Warning. Many folks have run into trouble by turning the ignition key on too soon. If you don't pump up the brake pedal until it is all the way up and firm before turning on the key. You will get a low pressure fault.
Mine were mushy also, when I had the front brake pads replaced they bled them and now it's hard.My 2012 RT calls for a fluid change at 14,500 or 2 years which ever comes first. I had mine done at 14,500 and it was actually 4 years. The fluid looked really bad. I had it done by the dealer that time but will try it myself next time which will be this spring when the world warms back up. I am pushing 36,000 miles and it is coming up on 2 years. BTW I don't like the brakes on the 2012,they always feel mushy but I have had them bled twice with no change.
Yes, I replaced my master cylinder and the dealer told me that they had to bleed the brakes, because you can't do it without the buds system. I told him to go screw himself that I could do it myself.OK, here's the latest......
a member gave me a print-out of the manuals BRAKE SYSTEM...
To perform a COMPLETE BRAKE SYSTEM BLEED, the manual states to start with: 1. Left Front Caliper, 2. Right Front Caliper, 3. Rear Caliper & 4. VCM..... Question: what is a VCM...?
Then it states to: Connect to B.U.D.S. and log on... is it absolutely necessary to log on BUDS for the system to work properly....? Or can this be eliminated...? has anyone NOT logged onto BUDS with good results...?
I guess my 20 years away from this type of work, and all these electronics has left me in the dark...
Dan P
SPYD3R
Does anyone know if stainless steel-wrapped brake lines are available? Just curious.
I have to kep adding fluid a very couple of months. Maybe mushy is better
