My main concern with pugging off vents for your comfort.... is where is the heat going.. or not going.... for me.... I will not insulate the tank( at this point, the fuel tank is a heat sink) or plug anything.... until I can eliminate the sources of the heat. There are a LOT of things under the Tupperware that are not friends with the heat....ie brakes master, computer and associated controls...efi to name a few.Last week I added heat reflecting insulation to the back of the tupperware near my left leg to reduce the heat. There was some improvement but not much. I was then thinking I will have to wrap the pipes next. Yesterday during my after supper ride I was feeling around for all the areas that are hot and realised how much hot air was blowing out from under the seat and on the left side it was extremely hot air. So today I took a look and found that there is big opening under the tupperware leading under the seat. I do not remember that much space on my 09 GS.
View attachment 70671View attachment 70672
I then stuffed shop towels under the tupperware into the opening to block the airflow.
View attachment 70674View attachment 70675
The reduction of heat and the improvement in rider comfort was very big. I then removed the towels and went for another ride. That confirmed that plugging that opening was a big improvement. I am still not sure if it will be enough for me but I have decided that it will be my next project.
I would not recommend anyone stuffing towels in their Spyder and thinking it's fixed. Spill some gas on the towel and you have the making of a molotov cocktail.
Was thinking of carving some closed cell foam to make an air block for that area. Any better ideas folks?
