should i use the top block off plate or both top and bottom
My next step will be to remove the large plastic air box and associated pipes and attachments which gets hot as well and also blocks lots of airspace above the motor. Other folks who have done this report lots of heat reduction in the upper body panels and on the heat gauge.
does the bottom pan protect anything vital and whats it for ? i'm thinking of dropping it so it will direct the heat out the bottom of the bike and away from my feet
(Maybe I mised this...)
What year is your bike?
It's pretty tough to remove the pans off of the 2013s... :shocked:
If you've got a prior year's model; you can, as they say, punch a bunch of holes in it to let the hot air have another escape route... :thumbup:
Placing holes in the plate seems the best plan. There are some important parts under there that could be damaged. Properly placed holes will vent nicely and still have the protection. They were placed there for a reason and it's not for the look. Jmo
Good advice!Before you buy anything i would start with just removing the pans and see what it feels like. Then add other stuff as you go. Be careful just piling on devices to redirect heat as it has to go someplace. The pans really serve no purpose as the motor is designed to get wet, dirt that gets up there can be washed out and it does trap heat. I have mine removed (RT) with no negative effects. The heat was slightly reduced. My next step will be to remove the large plastic air box and associated pipes and attachments which gets hot as well and also blocks lots of airspace above the motor. Other folks who have done this report lots of heat reduction in the upper body panels and on the heat gauge.
