Oklahoma Spyder
anyone fix their disk brake squeek
Intimidation?I don't understand. How would wrapping the pipes eliminate the brake squeal?
Cheap Chinese labor, anyhow!BRP HAS SOMEONE ELSE MAKING BRAKE PADS. ORIGINAL COMPANY CHANGED THE COMPOUND BEFORE MANUFACTURING. CONTACT YOUR DEALER FOR UPDATES
It has served me well for nearly 40 years now.I just have to comment that the picture of you on that motorized tricycle is hilarious! It's great!!!
It has been suggested that he close proximity of the exhaust pipe to the hydraulic brake lines might cause the brake fluid to overheat. Wraping the pipe prevents this. Seems to have worked and lessened or eliminated the squeal for many of those who tried it. :dontknow:
Richard
I had the same problem, the crc brake clean and crc disc brake quiet seems to take care of it. I think it fills in any light grooves in the rotors and that seems to do the trick. Cheap and easy. Well worth a try. No need to pull wheels or brakes. Onlt takes minutes.
You need to apply the crc disc brake quiet after you use the clean for the best results. Just apply cleaner again let dry and then apply disc brake quiet, go for a ride and apply the brakes about 6 times and you will be golden!!:clap:
Aside from relieving the brake squeak did you notice any performance gains or less heat coming from the engine bay?Wrapped the pipes on W's Spyder. Tech had done the stuff on the backs of the pads at the first service to no avail. Skweeeeel is gone since the pipe wrap.
