Brake Test : Spyder vs Motorcycle
i would have to agree I don't know how they did this test against a bike but my BMW would way way out stop my spyder more room for bigger brake rotors and 200 lbs less weight advantage bike ,also lots of the new bikes also have abs when I see a spyder do a stoppee then ill believe
Good one; about the stoppee! :clap:
My old GSX-Rs and my current Street Triple both out brake my Spyder. Stopping 450lbs vs 900lbs in a straight line is no contest. Now.. in the rain in a curve.. different story.
Some two wheelers might? stop shorter than a Trike, But let me tell you with a full bore emergency stop, You'll have a lot less drama with a Trike, ie, when you don't expect to make an emergency stop and have to do it like right now!!:yikes: And in real world conditions not a controlled test.....
I don't know, maybe there's something wrong with the brakes on my 2010 RT. They are just adequate, that's all. I don't know what BMW touring bike they tested but my 2000 BMW R1100RT had much better brakes and the 2003 BMW F650CS that I have now stops better, also. Both BMW's have Brembo ABS brakes. My 1972 RD350 Yamaha with non-ABS drum brakes would also stop better. Only my 1975 BMW R90/6 had poorer brakes and it had terrible brakes. I will agree that, in an emergency stop situation, the stability of the three wheeler is an advantage but I'm not sure that will make up the difference in sheer stopping ability. I haven't ridden a 2013 Spyder but I expect that the Brembo brakes on the 2013's are better. Cotton
