Peteoz
Well-known member
Hi Guys and Gals
There seems to be some confusion among both BRP techs and owners as to the correct torque specs for the rear axle nut for the RT and F3. It appears that it changed from 96ft/lbs to 166ft/lbs in around 2014 (perhaps to coincide with the 1330 motor?).
The trouble is, some BRP techs are telling 2015/2016 owners that the axle torque should be 96ft/lbs and are setting the torque to that when they refit the rear wheel. I am not sure if they are doing that because 96ft/lbs is the torque they have always used and are unaware of a change, or if the 2015/16 service manuals are shows the wrong setting at 166ft/lbs.
Is it possible to get a clarification from "the horses mouth", so to speak as to the correct torque specs for the RT and F3 please and when (if?) it changed from 96 to 166ft/lbs? I am a bit worried that some are using 96 when we should be using 166, which may cause issues down the track.
Regards,
Pete
Regards,
Pete
