Caliper repair kit needed!
Sungate
Need a front caliper repair kit for my f3. I can't find anything similar, although this caliper has been fitted on many motorcycles. Need help!
I don't know if you can get a kit for one of these issue or have to get a whole unit!! Possibly a person could go direct to the brake manufacturer!!!:dontknow: Good luck!!
Can only partially help, parts are not available from the Can Am dealer. However, and I forget the company, but there is supposedly a Brembo supplier that may be able to supply parts here in the USA. My Can Am dealer told me who it was a while back, simply forgot.
Today I disassembled the caliper. I think I found the cause of the jam. Brembo clearly has quality control problems...
One of the seals was clearly damaged when the piston was installed.
If it's a new F3 it may be under warranty. PW2013STL's link may be a good source for seals and pistons. If not try Napa. Also, inspect the piston cups for any pitting or out of roundness. If you can't hone out the defects then you need a new caliper. Good luck.
My f3 is out of warranty for a long time but the caliper was removed for the first time. I found no more defects. Pistons in excellent condition
Sometimes you can't/don't always see/feel the small imperfections. Clean it up and put in a new piston and seals and reinstall and see how it works. Bleed both front calipers to make sure there are no air bubbles sneaking around in there. Good work Sungate.
All f3 and rt are equipped with a brembo p4 32mm caliper. All of these motorcycles have the same caliper, pads and oil seals.
Thank me if this is helpful to you.
APRILIA Tuono V4R - APRC ABS 2013-2014;
APRILIA Tuono Factory 1100 V4 2015;
APRILIA Tuono 1100R V4 2015;
APRILIA Caponord 1200 2013-2014;
APRILIA Caponord Rally 1200 2015;
BENELLI BN 600 R 2014-2015;
BENELLI BN 600 S 2014-2015;
BMW F 800 R 2015;
BMW F 800 R Sport 2015;
BMW R Nine T 2014-2015;
BMW R1200 GS 2013-2015;
BMW R1200 RS 2015;
BMW R1200 RS Sport 2015;
BMW R1200 RT 2014-2015;
BMW R1200 R 2015;
BMW R1200 R Sport 2015;
BMW S1000 XR 2015-2017;
DUCATI 803 Scrambler Icon 2015;
DUCATI 803 Scrambler Full Throttle 2015;
DUCATI 803 Scrambler Classic 2015;
DUCATI 803 Scrambler Urban Enduro 2015;
DUCATI 803 Scrambler Flat Track Pro 2016;
DUCATI 821 Hypermotard 2013-2015;
DUCATI 821 Hypermotard SP 2013-2015;
DUCATI 821 Hyperstrada 2013-2015;
DUCATI 821 Monster 2015;
DUCATI 821 Monster Dark 2015;
DUCATI 821 Monster Stripe 2015;
DUCATI 899 Panigale 2014-2015;
DUCATI 939 Hypermotard 2016;
DUCATI 939 Hyperstrada 2016;
DUCATI 939 Hypermotard SP 2016;
DUCATI 959 Panigale 2016;
DUCATI 1200 Multistrada 2015-2017;
DUCATI 1200 Multistada DVT 2015-2017;
DUCATI 1200 Monster 2014-2015;
DUCATI 1262 XDiavel 2016;
MV 800 Rivale 2014-2015;
MV 800 Stradale 2015;
MV 800 Turismo Veloce 800 2015;
MV 800 Turismo Veloce 800 Lusso 2015;
NORTON 961 Commando Cafe Racer 2015;
NORTON 961 Commando Dominator SS 2015;
NORTON 961 Commando SF 2015;
I tried my best for all of you
Rear calipers - 2015 F3S - Repair Kit/Seals
Hi all,
The rear calipers - is there a model number or type that I can quote to a Brembo guy - I need a repair kit/seal kit for the rears only.
Any help appreciated.
Look for the part number on the caliper.
Or take it off, unscrew the piston and measure it
Find out from him what is the number of the repair kit for the front caliper. Brembo p4 32mm caliper. Only rubber seals without pistons are needed. I will be grateful to you
