Can I unplug the parking brake module - need micro switch part#
tommartin
I know there are several posts on the parking brake, but I can't find them for some reason. My micro switch handle fell out and now there seems to be no limit switch; the pulley makes a full round and the cable jumps out! While I do ride a manual, I still like to set the parking brake.
Also, can I unplug the module & stop that beeping while I wait on parts, if I ever find a number for them?
i know there are several posts on the parking brake but i cant find them for some reason. my micro switch handle fell out and now there seems to be no limit switch, the pully makes a full round and cable jumps out, while i do ride a mannual i like to set parking brake, also can i unplug the module & stop that beeping while i wait on parts if i ever find a number for them?
Hey Tom. If by "handle" you mean that little arm, with the little roller on it, that pushes down on the switch button - then here's your part number:
710001379
It's the same micro switch that is used for the brake pressure switch, So that's why it will be called brake pressure switch in the parts list. Just drill out the two little rivets and remount the new one with screws.
Unplug the beeper? Waste of your time. Comes from the cluster, I believe. Not a stand alone unit. You'll get used to it.
710001379
Thanks. That's the one I'm looking for.
