JKMSPYDER
Well-known member
Today I went to crank my Spyder and the check engine light and orange screen came on. No codes. I removed the key for a few seconds, reinserted it and still got the check engine light. After trying this about three times, I took the key inside and brought out my other key. Got check engine light again. Took key out, walked down my driveway for about 5 minutes to clear my head, then tried again. Spyder started up fine, no light and no orange screen. I took it for a 50 mile ride with no more problems. The original key is in an IPS key holder and stays in the Spyder 100% of the time. I have had the check engine light problem occasionally, say once a month or so. Usually by removing the key and reinserting it, everything is OK. But today was different. I'm wondering if the nanny threw a tantrum because the original key is always in the ignition? Would it be advisable to take it out occasionally, say overnight? Or is something else going on?:banghead::gaah:
