Lamonster
SpyderLovers Founder
Well I hate being wrong but I'll be the first to tell you when I am.
pps:
There have been quite a few post about the temp bar reading hotter after the cluster update was done to fix the odometer rolling over at 62,137 miles. I said there was no way that this update made the Spyder run hotter and I was right and wrong at the same time but mostly wrong. I wouldn't have given this a second look if it wasn't for BajaRon saying he noticed after we both had our clusters updated that his Spyder was running a bar or so higher. I never watch my bar because I have a temp gauge and I keep a close eye on it and I didn't notice any change. So we get to our dealer yesterday and ask him if he saw the same thing after the update and he said he didn't notice a change but he did hear there was suppose to be a fix for that coming. So now I'm really wanting to know whats going on so I took the RS/GS out today and kept a close eye on both my temp gauge and the bar gauge in the cluster and sure enough it has changed.
Here's what it read before the cluster update and after. Before is in Red and after is in Black
@175 degrees I hit 4 bars
@110 degrees I hit 4 bars
@197 degrees I hit 5 bars
@172 degrees I hit 5 bars
@202 degrees the fan came on
@200 degrees the fan came on
@190 degrees the fan kicked off
@188 degrees the fan kicked off
I also noted that my ambient temperature was reading higher between 12 to 14 degrees compared to the bank clocks.
So what does all this mean?
Forsure if you're now seeing 5 bars sooner than before the updated cluster you're still only 172 degrees so it's not running hotter even though the gauge says it is.
I have no idea why this changed and I heard nothing about it when I was at the tech school last week but my dealer seems to think there is a fix coming and I'll try and find out as much as I can and report back.
On a side note my dealer also said the fix for the throttle body on the RT is ready to be installed. Just hope that's all it changes.
