Could disconnecting the positive terminal of the battery for a few days cause any problems?
Always disconnect the negative cable first. Then reconnect the negative cable last. In other words. The positive cable should always be attached when you connect or disconnect the negative cable.
Other than this, I see no issues with removing power from you vehicle.
