Could disconnecting the positive terminal of the battery for a few days cause any problems?
Always disconnect the negative cable first. Then reconnect the negative cable last. In other words. The positive cable should always be attached when you connect or disconnect the negative cable.
Other than this, I see no issues with removing power from you vehicle.
If you have a Can-Am Spyder of some type look in the operator's guide table of contents for Battery and go to that page and you will find this warning: NOTICE Always disconnect the NEGATIVE (-) cable first to avoid damaging the electrical system of the vehicle.
Yup ASE has the same recommendations. Most new auto systems are "ground" switched power, ie. hot is connected all the time to the item, then when the ground connects, it completes the circuit to make it work.
