Cruise Control ~ need guidance on attaching servo cable to throttle pulley
twoseas
Hi all,
I'm installing an electronic cruise control that is a Rostra unit ( replacement for Audiovox unit ) on a 09 SE5. I attempted to use the supplied loop cable to piggy back it to the throttle cable but the the throttle cable barrel slides into a recess and it will not allow the loop cable to fit.
I've seen a few pics posted on here showing one installation where the pulley was drilled and riveted. Another pic showed the servo cable attached to a lever beyond the throttle cable pulley but my throttle body does not resemble that picture.
So if anyone has some guidance and/or pictures that you can offer, it would be much appreciated.
You can reply here or PM me.
Thanks in advance,
Ray
Lamonster,
Thanks for the reply. Can I pry that plastic lever off without dissasembling further ? It appears that your loop cable is shorter than mine. My bead chain connector ends up flush with the bracket that holds both the throttle and return cable.
Thanks,
Ray
This is where I hooked mine.
attachment.php
Be sure there is VERY LITTLE PLAY or Slack in the throttle cable. I left about 1/4" of slack in the plastic sheath (going from the servo to the threaded adjustment part that mounts to the throttle assembly). I had some issues with engagement and holding steady speeds. I took virtually all the slack out of the cable and it solved all my problems.
You do want just a bit of slack because you want the throttle plates to return to their stop without restriction, but that's about it.
Lamonster,<br>
<br>
Thanks for the reply. Can I pry that plastic lever off without dissasembling further ? It appears that your loop cable is shorter than mine. My bead chain connector ends up flush with the bracket that holds both the throttle and return cable.<br>
<br>
Thanks,<br>
<br>
Ray
<br>
<br>
I did mine a little different. I hooked the cable to the other end of the bell crank. I used the ball on the throttle body arm instead of the ball on the throttle and then used the bolt that holds the factory throttle cables in their bracket for mounting my cruise cable holder. I had to loosen the bolt that holds the throttle body arm to get enough slack to ge the bell crank off and then back on. Just make sure you dont take the nut all the way off if you choose to go this route.. Basically the only difference is mine pulls from the bottom at a slight up angle and Lamonster's pulls from the top. Many different ways to skin a cat. I chose the way I did because I thought it gave me a really good place to mount the bracket to hold the cruise cable. I also think that bajaron makes a good point about the slack in the cable. I used three balls from the supplied chain to get my slack. I'll try to post a picture later tonight.<br>
<br>
I should also add, I've done my share of installing this cruise but this install was by far the fastest yet. I owe that to this forum and for that I say "Thank You"<br>
<br>
David
BajaRon,
Thanks for your input about the slack in the servo cable. I have a question regarding this cable slack. I mocked up the cable loop to the ball where Lamonster installed his setup and placed a bead connector between the loop cable and the servo cable. I then held the servo sleeve in my hand making sure I held it straight in line with the loop cable and worked the throttle via the handlebar grip and the servo cable doesn't really retract smoothly back into the sleeve. The cable tends to droop some before it retracts back into the sleeve. I believe this is because the loop cable is of a smaller diameter than the servo cable and therefore not as stiff as the servo cable.
This leads to another question, if you're rolling down the road doing 60 mph and you set the cruise control doesn't this slack/droop in the cable make the setting of the speed somewhat of a jerky reaction ?
For what its worth, the Rostra tech support told me that I didn't necesarily have to use beads between the servo and loop cable.
Thanks,
Ray
<br>
<br>
<br>
<br>
David
David,
Thanks for your reply. I'm still working on finding a happy medium for installing the servo cable and the mounting bracket. If you read my reply to BajaRon, I was told by the Rostra tech support that I didn't necesarily need to use the beads to provide the slack in the cable.
Correct if I'm wrong, but this is what I envision as a proper installation. With the throttle wide open, locate the furthest travel of the bead chain connector. Install servo sleeve bracket where the bead chain connector comes close (@ 1/4") to the servo cable sleeve but will not make contact as to not restrict wide open throttle because that would be the maximum travel of the servo cable. And per everyones advice provide a little slack in the servo cable by moving the sleeve closer to the throttle.
Am I on the right track ?
Thanks,
Ray
BajaRon,
Thanks,
Ray
I didn't use any beads for my install. Really, all you're looking for is a clean, straight, unobstructed path for the cable and a good connection point to the throttle. As long as the cable is the correct length and it works without binding or hanging up on anything it really doesn't matter how you achieve it.
David,
Thanks,
Ray
I am doubtful that the cruise control will ever get close to wide open throttle. Still, it's probably a good idea to make sure the cable is free to go that far just to be on the safe side.
David,
Thanks,
Ray
Ray, I have seen this done many different ways, lots of slack, a little slack... I don't like lots of slack due to the risk of the chain getting hung up although I can show you several installs that work great that way. I my opinion, what's important is that you don't run out of travel in the servo. I use the balls so my connection to the throttle has some room to move without trying to push the servo cable back into the servo.
The amount of slack in the cable at closed throttle didn't seem to make any difference in the vacuum cruise controls I installed. That's why I didn't pay that much attention to it with my Electric Servo unit. But it sure made all the difference in the world with that one. Not really sure why that is because you've got the throttle open when you engage the cruise control and that means a fair amount of slack that has to be dealt with initially. All I can say is it made a big difference.
BajaRon/David,
Thanks for all your help so far ! I've been dwelling over the whole slack cable thing and where to make the connection from the servo cable to the throttle. Because of you input and Lamonster's I now have the confidence and options to proceed with the installation and for that I thank you.
I may have to pick your brain some more when I get to hooking up the wires.
Thanks again,
Ray
BajaRon/David,
Thanks again,
Ray
I played around with a few different connection points (which then dictate your mounting point for the cable bracket) before settling on the location in Lamont's photo. That one seemed to work best for me. But it also depends on how you configure the terminal cable connection (which I modified for my connection).
Once you get in there you'll be able to see better what needs to be done. Then it is simply a matter of hooking it all up. You'll be very glad you did. I use my cruise control all the time and love it.
BajaRon/David,
Thanks again,
Ray
Ray, I'm sure all will go well and you will be using the cruise in no time. I'm glad to add what little I can to the expert advise already available on this forum. The first time I installed the CCS-100, on a 1999 Valk Interstate, I remember wandering if it was going to be worth all of the trouble. Not long after it was installed I rode from Asheville, NC to Ardmore, Ok with only stops for food, gas and a couple of rest stops, 1030 miles.... I've been sold on them from that time on...
If I can do anything else just let me know.
David
Installing rostra electronic cruise control.
Attempting to install a rostra electronic cruise control on my 2009 SE5 Spyder. Where did you mount the module?
Thanks, Dennis
Servo Install Location
Thanks, Dennis
Here's are some pics of the servo install. I took lots of pictures let me know if you need anything else.
Ray
Thanks Ray.
Your photos helped a ton. How and to what did you anchor your cable? I am attempting to find or make a different cale loop attachment as the one I was sent does appear to be too long. Again, thanks for your assistance. It is very much appreciated.
