CyncySpyder
Teddys favorite human
Thank You once again Scotty, I'll try these suggestions once I get home today
I'm curious tho as to what I've done to cause this, as I tried originally to remove the Axle Bolt with the Spyder lowered and had no luck, so that's why I thought raising ther Spyder would help:dontknow:
The tire is totally flat, so I guess I need to put some air in it so that it can support itself, or was that why you mentioned using a block? I did have to drive on the tire totally flat for about a block & a half to get to the service station where I added the fix-a-flat, not sure if that caused this issue or what:banghead: I was able to get it to come out about another 2 inches last night, but now it seems more solidly stuck than ever:banghead::bdh:
