Day trip at freeway speeds on a 600.
I don't think the RPM's is gonna hurt anything but the noise and buzz at that high of a speed for a long time could be rather irritating.
I drove a 600 ryker home for my wife,50 miles.Ran speeds 60-75 mph.Not like the rt ltd I had,rpms ran 6000-6600,ride was so-so.I wouldn't do it again.Seems it is made for lower speeds and shorter trips,I was not comfortable running at those high rpms and speed.
I wouldn't mind the noise since I plan to have music going on the helmet, My main thing is the bike and the engine at those RPMs for a prolonged time. I work about 35 minutes away but it's literally ALL highway averaging about 70MPH the whole time.
I plan to use this bike daily (whenever the weather permits) in the summer which will also help with controlling the mileage on my other cars, lol.
I think I would opt for the 900, my Rally is on order, cant wait.
The max Horsepower for the 600 is 47 at 7300 RPMs. I would imagine you could run all day at 1000 RPMs below the max horsepower setting.
Can you rephrase that? Hard to decipher what you are saying.
Actually, at Can-Am website, it says 50. 47 must have been a preliminary number.
My experience with my 600 ACE running at 70mph the RPMs were between 6000-6200. That's more than a 1000 RPMs below the RPMs for max horsepower. In my mind running at 70mph for extended periods should not be a problem.
From: https://can-am.brp.com/on-road/ryker/recreational/ryker.html
BORE & STROKE
2.9 in. (74 mm) x 2.7 in. (69.7 mm)
POWER
Rotax 600 ACE Engine: 47 hp (35 kW) @ 7300 RPM
Rotax 900 ACE Engine: 77 hp (57.5 kW) @ 7100 RPM
TORQUE
Rotax 600 ACE Engine: 35 ft-lb (47 Nm) @ 6200 RPM
Rotax 900 ACE Engine: 56 ft-lb (76 Nm) @ 6300 RPM
This is a great place for the after market CVT tranny tune ups. Simple to do and a lot of info in the ATV, Side by Side and the like market place.
I think you're right, the 600 should be fine...I've been following Fastryker for tuning updates and think it would get better.
Per their website - With this tune, you will experience the following:
Increased acceleration
Increased throttle response & less throttle lag
Moderate changes to normal mode
Higher RPM limit
increased fuel efficiency in cruising RPM's
Access to maps as we upgrade. (working on removing traction control, possibly adding sport mode)
Higher RPM limit
Just keep in mind, any of that will void your warranty.
