Do the 2020 RTs (base) come standard with fog lights?
MONK
I must have missed it somewhere in my forum search but do the 2020 RT base models come with fog lights? If so, are they LEDs like the headlights? If not, is there an aftermarket supplier for these? I would assume the fog lights (if there are any) would be in the same light bar that the headlights are in.
TIA
No fog lights - the light bar has low and high beam LEDs
Photo shows low beam
I haven't searched for fog lights but I'm sure Google would be your friend
Google didn't come up with anything other than that extra light at the bottom. How well does that work? Is it just for show or does it help your night time vision?
I've searched for fogs as well - nothing either
My aux light is generic: AutoFeel LED Light Bar 2PCS 7 Inch 60W LED Pods Flood Spot Beam Combo Off Road Driving Fog Light for Truck ATV Boat (amazon 2 for $24) it is bright very bright - haven' used them at night yet.
The light fit perfectly and is just pressure fit in - I've ridden over some terrible roads at high speeds and it hasn't budged.
MULTIi-ANGLE BEAM FOCUSING:Middle 170° flood light surrounded by dual row 30°concentrated spot light,and Increase the floodlight on both side of the spotlight to bring extreme distance and broad area.
INCREDIBLE BRIGHTNESS: Superior-quality 3030 Led Chips with high light efficiency, 6500k bright white light, delivering 60W & 5500lm effectively light up entire forward dark road.Drivers can see farther and wider range of view at the lights.
EFFICIENT HEAT DISSIPATION & ADVANCED BODY DESIGN: 2835 chip flip-chip technology that provides better heat dissipation, low thermal resistance design.Black Painted , Die-cast aluminum housing and toughened optic lens,higher light transmission rate with PMMA lens.
DURABLE QUALITY LIFESPAN: IP68,Whether it is raining or snow,waterproof 68 design for all-weather uses.Rustproof, dustproof, shockproof and quick cooling aluminum alloy heat sinks effectively extend the lifespan.over 50,000 hours life span
The aux. light comes on and goes off with headlights
I'll ride tonight and post.
The aux light does put light close on road and the sides. A bit pricey but plug n play.I'm glad I have it.
Hi - did my fun night ride - same as poster woods above noted with BRP lights, my lights are very very bright and light up directly in front of bike and out a ways on road, as well as sides.
I can't really tell how far in front they project because they blend in with low beams of headlights - plus u cannot run them separately from headlights.
Since the riding position on the RT is that we sit on it up high, I think these lights prove a useful function in day for cagers and night riding for cagers and oneself.
Also, since the lights are so low I didn't get any flashing of lights from cagers.
BRP website says their fog lights work for all RTs - expensive
RT and RT limited seem the same to me other than add-ons that come with Limited. Price of all add-ons bought separately make the Limited cost effective.
Here's the lighting on my RT Limited.
I hope this helps
attachment.php
I like the added lights a bunch 3wheels! Were they a PIA to install?Guessing they function as turn sigs also?
You cannot have to many lights. :yes:
I have LOTS of them on my F3L...and IMO, worth every extra $$.
