I see that the RT idler pulley service kit, 219800419, only fits the 2014 to 2019 models. Did BRP change something on the new models or is there an idler that comes stock on them? I didn't lay on the show room floor and look at the belt when I ordered my bike. Thanks for any info.
Jim, I am picking my 2021 RTL up today, it has one from the factory. BTW I grew up in Robert's County (Peever SD).View attachment 189222
Fun riding around the hills above Peever. Very pretty country. GO SOUTH DAKOTAJim, I am picking my 2021 RTL up today, it has one from the factory. BTW I grew up in Robert's County (Peever SD).View attachment 189222
Just pickedup 2021 RT limited dark and mine doesn't have one, and no vibration to 70mph. Might have to rebalance the front tires cause I get a little there but it may be the spring roads.
My 2021 RT-L came with a belt idler, and the 20/21 workshop manual shows one in situ whenever they show a diagram of the left side behind the cover. Makes you wonder if one came with the ‘20 models, pre dealer assembly, but some dealers couldn’t be bothered putting it on, along with neglecting to bolt on the ACS sensor rod, checking tyre pressures etc.
Pete
The 1st edition idlers proved to not last very long so a decision was made to leave them off. BRP must have went with a better bearing on the newer ones.
.Just purchased a 2021 RT Limited and have only put about 1,500 Kms on it so far. I think I'm experiencing the harmonic vibration you guys are referring to. For example, at 115 KPH (70 MPH), I will get a shudder/vibration for about 15 seconds, followed by about 10 seconds of perfectly smooth riding, and then this cycle repeats. The duration and intensity of these cycles change a bit depending on speed, but is experienced all the way from 105 to 120 KPH ( or about 60 to 75 MPH). Am I correct in assuming that this is the RT's drive belts annoying characteristic?
So, from all my reading here, I thought this should be a simple fix by installing a belt top tensioner. But, had a llook underneath and my unit already has the factory tensioner. So ... now what?
By the way, I just had the RT over to the dealer for a minor warranty issue, so had them recheck the belt tension and alignment. They stated that the belt was still on spec.
Any suggestions would be much appreciated.
