Yes, I make sure I have a longer stopping distance than I do when I'm not pulling my trailer.I was wondering if having a trailer attached to your Spyder forces you to change way you ride, for safety?
Like when I have a passenger, I feel like I have to turn much slower than I normally do.
The 2012's had trailer mode as well. From the manual: NOTICE If the trailer mode is not selected through the infotainment center before towing a trailer, engine components might be damaged.On my 2013 Spyder, there is a setting for trailer towing. What does that do? Guess I should turn it on and find out.
Thank you all for input. I was mostly concerned about handling characteristics.
By the way, how much weight do you think these hitches can hold? I was thinking about making a golf club bag holder to screw on in place of the ball when I’m not pulling a trailer
I was told that it delayed upshifting making a higher RPM shift to make sure the transmission clutches didn't slip or lug.On my 2013 Spyder, there is a setting for trailer towing. What does that do? Guess I should turn it on and find out.![]()
I recall seeing a shock absorber addition to an OEM Spyder trailer hitch mount somewhere. Damned if I can remember now where I saw that. Does anyone else remember seeing it?^ Wot 'e says!!
I've seen a LOT of trailers (including a few BRP trailers) damaged by the constant pounding they get from the OEM Hitch or the clones of that swingarm mounted hitch; and I've heard of quite a few more experiencing similar failures, well into double figures!!![]()
