Downshifting
Bogie
Greetings to the group.
Again as I am still new and do not yet have my Spyer, I have a question regarding downshifting on the 2014 semi automatic.
I know it will downshift automatically, can you still downshift manually if you are passing or want to kick it up a notch?
Thanks in advance,;)
Bogie
Bogie
Yes.
Absolutely! :thumbup:
I used to kick mine down through the gears manually, when slowing for stops...
But now; I pretty much only downshift for the above-mentioned passing manuevers, and for a bit more engine braking as I enter sharper corners too! :clap:
The "Normal" stuff; I give the helm to the computer! ;)
Bogie
Only let it down shift automatically when you are too busy or too lazy to do it for yourself. Depending on your rpm down shift before accelerating.
