I have the same issue. However, I have learned that it is "normal" and my bigger issue is the surging I get at a steady cruise, but thats another topic.
I talked to 2 bro's racing and they say its always there, but you just don't hear it with the stock muffler, just the aftermarket units. Basically when you let off the gas, the spark is also turned off, so the fuel is not combusting in the pistons.
I also found this article to be interesting:
Deceleration Backfire is caused by fuel burning in the exhaust manifold or header.
No ifs ands or buts, that’s what causes it. But the bigger question is how does gas get there in the first place, and that’s a bit more complicated. Generally, there are a variety of ways it gets there, and a variety of things that can make the backfiring worse. But there’s a kicker, and something you should understand before we go any farther:
A motor in perfect tune will exhibit deceleration backfiring.
Therefore, just because your motor is banging it up, doesn’t mean there’s anything wrong. And consequently:
Getting rid of the noise means de-tuning your motor.
Yup. If you’ve jut got to eliminate that popping, you’ll have to accept the fact that your motor is going to be forced to run rich to do it, and that isn’t necessarily a good thing.
Ok, so you’re driving along at some given rpm, and suddenly you decide to decelerate, and you reduce the amount of throttle. This causes an “overrun” – that is, the motors rpm is turning faster than the fuel provided can support, so the motor begins to spool down. This causes a couple of things to happen.
First, when you close the throttle, you are also closing the throttle plate. This reduces the air and fuel flowing into the motor, and increases the vacuum (lowers the pressure). This results in less air and fuel in the cylinder during the power stroke, which in turn results in a lower pressure in the
[COLOR=#c80000! important][COLOR=#c80000! important]combustion [COLOR=#c80000! important]chamber[/COLOR][/COLOR][/COLOR]. The A/F mix burns faster in proportion to the pressure applied? Well, when we reduce pressure this way, the mix burns slower. This results in two things happening.
1. The lower burning fuel generates less heat, and the cooling effect of the non-burning fuel tends to “quench” the flame front, or slow it down even further. Because the mix is burning much slower, the exhaust valve can open before all the fuel is consumed, and the unburnt fuel is ejected into the exhaust.
2. The engine designers, in order to promote smoother idling and better combustion, retard the spark when the throttle is shut, and this results in the mix being lit later.
So, now we end up with unburnt fuel in the exhaust, and burning fuel being ejected into the exhaust, and bang! Backfire.
So the bottom line, is: That backfiring is perfectly normal and expected. If you’ve just got get rid of it, that’s up to you. You’re entitled to set your motor up the way you want, and your goals are your goals. But don’t refer to it as “fixing” the popping. Rather, the correct way to think of it is “de-tuning a bit to get rid of the popping”.
You will get worse gas mileage by getting rid of it because you will have to run richer on decel inorder to raise the chamber pressure engough to burn all the fuel.
