Exhaust wrap
How long should the wrap on the exhaust pipes smoke for?
It is best to break the wrap in slowly. It will smoke less and last longer.
In other words, start up the bike and let it idle until you start to smell it. Then shut down and let it cool some.
Do this 2 or 3 times before you ride it. That helps the wrap cure before you really bake it with full heat.
It will smell for a little while but after a ride or 2 it will go away.
I only did the left side so far and it took about 100 miles before I can say the smoking was all gone. I did start and run it a few time when it was first done and the first time it smoked like hell I even got the hose ready just in case. I was told that I should have pre-soaked it first and or after I wrapped it should have sprayed water on before I start it, not sure if this was right or not but it will go away the hard part was while waiting for it to stop smoking a few time while at a stop light some people would look at the bike and me and there face told me they were thinking dude do you not see your bike is on fire kind of freak them out I believe.
I am considering this.... I assume it's wrapped around the exhaust pipe itself all the way up the manifold? Where do you get it at and what do you use? Might be a good idea to do this before departing on my cross-country trip. Every little bit helps!!
This does not sound like it is good for the bike to contain this heat.
I am not a mechanic, but this subject sounds interesting.
Yeah, I was reading up about them on my lunch break. Sounds like it's a great idea! I definitely will be ordering myself some.
It prevents the heat from radiating, and carries it away through the exhaust system......
Maybe the exhaust temp. isn't dissipated as quickly with the pipe wrapped. Won't that cause the engine temp. to go up.
I'm speaking from an air conditioning background. As the discharge temp. of the refrigerant gas goes up it causes the compressor temp. to go up along with the oil temp. In some applications they would run a section of the cooler suction line along the discharge line. Too high a compressor temp. would result in oil breakdown. The higher discharge temp. also reduces the compressor capacity.
I'm not saying that will happen here. But, maybe it's something to think about.
Actually, keeping the heat inside the exhaust pipe and out of the engine compartment is all good.
Hotter air travels faster effectively increasing the volocity of the exhaust gasses and increasing the efficiency of your exhaust system. Racers have known this for years. That is where this "Header Tape" got its start.
Anything that makes an engine more efficient will effectively lean out the mixture. However, fuel injected engines have some ability to compensate and add more fuel (carbs can't do this without changing out hard parts).
In this case I don't think it will give you a leaner mix. Instead, it should increase your power.
Some heat in the engine compartment is not a problem. But the Spyder is a little overboard in this regard. The airbox gets hot raising the incoming air temp. That will decrease power and increase engine temps as some cooling occurs with cooler incoming air.
It also heats up the gas tank. Hotter fuel, like hotter air, is less dense and will reduce power. Fuel is also a component of engine cooling so cooloer fuel is a good thing all around.
I'm not saying that you're going to see any huge difference in power if you wrap the exhaust. But you will see a noticeable reduction in engine compartment temps (which is the main objective here) and other side effects are all good as well.
All of your sensors, hoses, and other components will last longer and function better over time with a reduction of engine compartment heat. Your plastic pannels will also appreciate lower temps.
One more thing. You will notice that the engine is quieter when you wrap the exhaust. Again, not huge but noticable.
Just don't see how you can go wrong with this mod. I suggest the 1" wide wrap that is impregnated with graphite (Black). It comes in wider sizes which may seem like a good idea (covers more ground with less wraps). But the narrower stuff gets around bends more uniformly.
Check this out.
http://www.jscspeed.com/universal/thermotec/header_wrap.htm
Check this out.
Good information, thanks.
So, how many feet will we need for this cooool mod?
I have had my exhaust wrapped for about 3k miles and have had the Leo Vince for about the same amount of time and haven't had any major issues. I have noticed some increase in deceleration backfire, but it is not major. I did notice that the "under plastic" temps seem much lower and that is worth the risk of a lean condition to me.
I ordered my wrap from here: http://www.deicycle.com/catalog/1/motorcycle_exhaust_pipe_wrap_kits
If you leave the pipes on, it will be easier, just not as complete. I removed my pipes and did both sides. Some people seem to notice a big difference, but afer wrapping my spyder and my wifes spyder...at least on our bikes, we have not noticed it to be that significant of a difference, but then again, we live in Florida and its hot out here. One thing I did notice is my right foot gets even hotter...a lot hotter now since wrapping the right side and I'm not sure what that would be the cause of it, but I would think so since it now happens after the wrap. I did have the dealer check it for exhaust leaks and no issues there.
Today I installed a DEI insulated type of deal in the radiator area, so will see how that makes it feel on my next ride tomorrow.
If you don't remove the pipes, its a fairly easy mod, and if you get the kit, with the instructions provided, you will be fine.
Overly lean conditions are less likely in a system that has an O2 sensor in the exhaust, which will allow the injection to compensate for the higher flow. In a race system, without sensors, it is another story altogether, and you can most certainly damage components if you do not somehow richen your mixture immediately.
i have mine wrapped end to end but with recommendation from my current dealer and ken from evoluzione.net i will be taking them off. wrap is keeping the heat in and may cause premature gasket damage and others and was design to be cooled by the air flow inside engine compartment, according to both of them.
Exhaust gasket damage?
