Exhausting options
troop
Well-known member
Exhaust(ing) options
Well ... The latest bug up my butt is pondering an aftermarket exhaust. I'm currently running a Baldwin Ironworks cat delete pipe and modified baffle on my stock muffler. The two exhausts I'm considering are a RLS Twin Kaos and Two bros S1R. Reading reviews and watching video's, it is quite clear that both are loud. When I first installed my cat delete, I ran the supplied baffle with the end plug installed. The exhaust was slightly louder than stock, with the cat installed. With the plug removed it is about right, but with no baffle, it is a touch too loud for my taste. Now, with my preferred choices.
1.) RLS Twin Kaos: I'd likely run this exhaust with the baffle/end plug installed. If it is too loud, I can always try it with the OEM cat installed. Cost is $460 + $38 shipping = $498 Might need to wait for the next exhaust50 sale. Current wait time is about 20 days. Have to mention that Ricky S has been GREAT answering my inquiries.
2.) Two Bro's S1R: Comes with its own cat delete pipe. Videos show that my baffle will fit in the cat delete pipe. I'd also likely try it first with the baffle/end plug installed. Still too loud? For $28 I could add a Two Bro P1X suppressor tip for another 7db sound reduction. Best cost I found is $442 shipped. If I need a bit more noise reduction, the P1X tip is $28. That makes it about $470
Being in WI, I still have a bit of time before riding. Any input from RLS and Two Bro exhaust users?
If your existing system is about the right volume for you, then I think/am almost certain that you'll find either/any of those options you describe above will be a fair bit too loud for you!! :shocked: I'd think that you'd find the RLS system with baffle & the OEM Cat would be closest in volume to your current system, but it'll still be noticeably louder than what you've got now! :rolleyes:
As nice as they may look/loud as they may sound, do you really want that much more noise with little other gain?? :dontknow: Why not spend the money you'd spend on the a/mkt exhaust on an ECU Upgrade instead, and get some REAL bang for your bucks - hey, upgrade the air intake side to match the improvements you've already done on the exhaust side, get the ECU tweaked to take advantage of that, and you could step up to the next level of Spyder performance and make it the weapon it should've been from the start! :ohyea:
Agree with Peter, ECU update, is the way to go, I had my spyder tuned, after a cat delete, and an aftermarket Akropovic, which I welded myself. The sound was too loud with Original baffle, but I lenghtened a bit, and tweaked the sound that way. Hell under 3500 rpm, it's a purring kitten, above 3500 rpm it's a lion. Then I let a friend of mine write an tuning, and now the Spyder id performing like a Boss.
Last sunday went on a ride, and managed to pull out a Ducati (footnote, till 100km/h)
Airintake, is next on the list.
Thanks Peter,
I do have a DynoJet Power Vision 3/K&N air filter installed. I also had a custom data logged fuel/timing map made on my Spyder. If need be, I could also data log and make any corresponding fuel changes. I guess I'm also going for a sportier look, and a deeper tone would be a plus. Still undecided :dontknow:
Reinstall the cat, then have a long tailpipe made with no baffle, a good fabricator can roll a long stainless or 3/2.5 cone. If 3/2.5 they can color tone it.
If performance is key, and since time permits, remove the entire exhaust from the head to the muffler and get it done with Jet Hot inside and out. Reduce heat and increase performance by retaining heat within the pipe to lessen cooling and subsequent slowing of exhaust flow.
Pretty much know that I'm going to stick with my Baldwin cat delete pipe (unless I go with the Two Brothers exhaust) . To maintain back pressure, I'm going to purchase a longer baffle. I'll play around with it by using the plug in the end position, and maybe doing one wind of baffle wrap. The longer baffle offers me wore tweaking options.
Two Bro's installed, along with a modified baffle in the delete pipe. Sounds really nice..
