did not extend the pedal, only lowered the brake pedal
followed the You Tube video and read the directions (which are great and loong)
not a bad job to do-took me over an hour though as I was fiddling to find the right place for the pedal.
Wound up with it a little more than an inch lower than stock. I have pegs not boards.
If you try to get it too flat (the brake pedal) it winds up where it doesn't do the job and you have a hard time rolling your foot down. Don't go by how it looks, get on the bike and make sure it works for you-then tighten everything up and you're done. Just like you are told in the video.
Now I can use the brake without lifting my foot from the peg and without arching my foot up to a place it was not meant to bend.
All you need is in the kit including locktite (and it's blue, not the atomic kind BRP uses)
