Road-Kill, these are just a few of your many less than helpfull posts to this thread.
Your posts on this thread drive me nuts(probably your intention)! Your one of the less than 1%(your number) that this thread has helped!!! How can you possibly continue to criticize and call this tread BS? Please stop posting on this thread and let it help the people who really care!
Has anyone here actually changed out one of the pulleys themselves? Mine has a bit of red dust on it but out of warranty. Decided to just change it out rather than wait for it to fail. I removed the bolt, removed the belt but darned if I could get the pulley off. It seems to be rusted in place. I tried a pulley puller but there is not much room around the edge of the pulley and did not want to damage it beyond use. There are no threaded holes in the face of the pulley so a jaw type puller was all I could think of. It refused to come loose. I gave up, installed and torqued a new bolt and washer.
How does one remove this pulley, there is nothing in the service manual as its not a press fit, its supposed to come off pretty easily. Do I just wait for the rust to progress and the splines to fail then it will come off when loose?
I have spoken to a few Spyder techs I know and most come off without too much persuasion. Some do not and things can get 'bad' Seems there may be more wrong with the design than just the lack of proper lubrication on the splines.
I think you are right. Usually will fill in the holes.
This was sent me a couple days ago by a ryder. He is getting it replaced.
This is my sprocket after 10,500 miles. Guess it's time to call my original dealer, since the closer one in Stamford, CT never heard of this problem. I'll have them install a new belt that I got from Amazon, since they were telling me that mine was shot the last time I was there. Any suggestions on how to handle them if they put up a stink?
Is there a service bulletin # that I could quote, since this is the first they are hearing of it as well?Yep, yours got bit. I wouldn't tell them where you got the belt (has to be a BRP one anyway). I would just tell them you have a spare belt and would like it put on. Also, you might get them to warranty the belt. Ryder on FB just had his sprocket done and the dealer did the belt also.
Anybody have a # for the BRP service bulletin on the sprocket?Yep, yours got bit. I wouldn't tell them where you got the belt (has to be a BRP one anyway). I would just tell them you have a spare belt and would like it put on. Also, you might get them to warranty the belt. Ryder on FB just had his sprocket done and the dealer did the belt also.
I'll be going to the dealer on Wednesday, so hopefully they will then order the required parts. I'll bring a print out your response if they need a bit of a prod to contact BRP!As of a couple weeks ago, BRP still has not published a service bulletin on this problem. They are however, quickly and easily approving the replacements. If the pulley exhibits the red oxide dust, they authorize replacement as failure is approaching.
I do recommend re installation involve moly lube on the new sprocket splines as is industry practice. Installing dry is a known failure method for splines that are not press fit.
Thanks!
Just so you know, that dealer no longer sells Spyders, new or used. There are a lot of things they never heard of. Go somewhere else. I go to Arctic Adventures, a long way from me, but trustworthy, upright folks, and worth the trip.
Arctic Adventures? That DOES sound like like a long trip, oldguyDo you need an Inuit guide to get there?
Pete
Thanks for the heads up. They suggested that I bring it in for a look, so I definitely won't!Just so you know, that dealer no longer sells Spyders, new or used. There are a lot of things they never heard of. Go somewhere else. I go to Arctic Adventures, a long way from me, but trustworthy, upright folks, and worth the trip.
The mechanic told me that BRP would not authorize the work, but I found out that my warranty was not still in effect which was a surprise to me since I thought it was.. Well, one thing leads to another, as I will get in touch with BRP next! Wish me luck, as I will probably have the sprocket replaced regardless of the warranty question!Anybody with the red rust has not be denied to my knowledge. If they give you a hassle, make sure and report them to BRP. Information flow back to them is the best way for us to get the best possible service work done. I have sneaking suspicion that they will be really monitoring how their dealers are treating their customers even more so from here on in.
