On my '15 F3-S I upshift between 3500 and 4000 RPM with my SE6. I think anything above 3000 would be OK. I prefer to manually downshift and do that at about 3000 RPM. Hope this helps.
It depends on what your objective IS.Does anyone know what the recommended RPM range or "sweet spot" is for the F3 SE6? At what RPM is it recommended that you shift up?
But seriously: Last thing you want to do (IMO) is make an engine LUG, right?
~Someone please correct me if I'm wrong.
Oh come on Bob.....REALLY ???I shift into second at third at 2,000 rpm.
Fourth, fith and sixth get grabbed at 2,500 rpm.
I'm normally in sixth gear at 39 mph.
The bike doesn't lug: it just puts it's shoulder against the load, and makes magic happen!![]()
The engine idles about 1300 RPM so you are shifting only 700 RPM above idle.......with an engine that redlines at 8K ???
I don't believe in making like you are on a race track either but what you quoted above is extreme in the other direction.
At engine speeds that low things can happen suddenly that WILL lug the engine......and cause damage.
What you are doing is NOT good.
Loosen up a little.......or maybe you need to get a golf cart instead. :shocked:
The shifting is computer controlled: the bike will not let you shift too early! nojoke
CAVEAT: When climbing a steep hill: I will let the rpm levels come up a bit... :thumbup:
People worrying about lugging these engines can give it a rest.
You're trying to apply the warning given to owners of Post WW2 British sports cars. They had notoriously weak bottom ends in their engines, and they would break stuff if you didn't keep the revs up.
Rest assured that Rotax knows how to build a strong engine! nojoke
I have no personal knowledge of that......but am HIGHLY skeptical.
Just the numbers that you provided pretty much convinced me that it is NOT true.
ANY engine can be "lugged" and damaged......unless maybe an automatic transmission down shift saves it.
What happens with your machine if you approach a really STEEP hill at your minimum RPM in top gear and just hold the throttle steady as you try to climb that hill ??
Anyway, shifting like you claimed takes most of the fun out of riding. :banghead:
I can't believe that this discussion is ongoing... :banghead:
The fact of the matter, is that the 1330 has no sweet-spot: It really doesn't matter when you shift: the bike will like it just fine! :thumbup:
The answers in here tell a whole lot more about the riders; than it does the bikes! nojoke
If you don't want to believe me: try it for yourself just once... :thumbup:
Just because you are getting away with it does NOT change the fact that it is NOT A GOOD THING TO DO ALL THE TIME.
But I don't blame you for not taking my word for it.
The next time you are in a motorcycle shop......of any kind......Spyder is better.......ask every mechanic/technician that you can find about this.
Pick the ones who are over 40 years old. They don't teach stuff like this to new mechanics these days.
And then don't believe them either. .
