fault codes still on
steven888
OK, Checked and changed the relay, Still getting ABS, VSS FAULT CODES. Now I am getting a new fault code added to the others. EDB FAULT and the idle went up to 6000 rpms upon starting. Played with the relays some more. Started it again and went back to a normal idle then shut it off started it again back to 6000 rpms and back to normal idle. Drove it a little and now the EDB fault is gone.:dontknow:
