Front Fork Adjustments
Motogordo
Right now my front forks are set at 3 .
Front Tire Pressure : 18
Rear Tire Pressure : 28
Rear Shocks: 3
The ride seems pretty okay. What do I get by changing the front shocks up to 4 or 5 ? Is the slight swaying due to settings for front shocks ?:chat:
Gordon
I have a 2011 RT. With the stock shocks set to 3 it was a very smooth ride but I would get a lot of roll with fast turns. Changing the tire pressure to 20# in the front and the shocks to to 5 was the best setting for me with the stock shocks. The ride wasn't as smooth but it didn't roll as bad in the turns. I still had issues with high cross winds and the bike rocking. I ended up with Elka shocks in the front and 18# of air in the front tires and now all is well. Very little rocking with cross winds and very little roll in the turns. :2thumbs:
Rear Shocks: 3
Gordon
I liked my 2011 set at a preload of #3, but I like it better at #4 solo and #5 two-up. You will sacrifice some ride softness. The easiest way is to try the various settings and see what you like best.
Everybody seems to universally agree that adding preload and air up front improves things. The trick is to flavor it the way YOU like it and then leave it alone! nojoke
Front Fork Settings
I want to thank all of you for the information. I guess I will stay where it is for the moment. It is a shame that we can't adjust the shocks without lifting the front wheels. That would make it a lot easier.
Gordon:2thumbs:
Agree! I have never had a bike that had to be jacked just to change the spring load. I ride single and two up and to keep changing, well...I'm gonna try to find the happy medium...crazy! As for the slight swaying...I have not figured that out. Front shock settings, new shocks, air pressure..lot's of reasons I guess. I'm chalking it up to the DPS and two wheels.....it does not "hold the line" like a traditional bike with a single wheel up front and of course the steering mechansisms are way different...That's the hardest thing for me to get used to....700+ miles on my 2011 RTS.
A Spyder does not have the assistance of the gyroscopic stability that a conventional bike has, so it will not try to remain straight if influenced by steering, winds, or the road surface. If you are having direction stabilty issues, have your alignment checked. If you have a 2010 RT, pay to have the toe-in increased to the newest 2011 spec. You may also want to purchase the 2011 front shocks to cut down on the body roll, or go with aftermarket shocks.
Thanks all! Just to clarify, I have only been riding bikes since 2005. A few years. My Spyder is a 2011..total stock. Got the "grip" thing, but that is not always possible in heavy fast moving traffic or on the twists. Putting around town, OK. It's at it's worse just cruising down the highway at 70. The swaying (no wind) is due to road conditions and the DPS. This is just something I need to get use to and with time and miles, I already see improvement. Upgrading stock vehicle at these prices is my last resort.
Dawg, if you have a 2011, try your shocks at 4 with 20# in front. It should be steady at 70 with no wind. If a little too firm, reduce pressure to 18... Ya gotta play with it to get it to suit you. BRP upgraded the shocks on the 2011.
:spyder2:
I am aware that the front end needs to be lifted off the ground while adjusting the front shocks, but I still haven't read where the jack should be placed. I look under my 2011 RT and don't really see any place that looks strong enough to lift the weight. Pictures would be a big help, if anyone has some.
Thanks in advance for any help or suggestions.
With an ATV jack, you jack under the horizontal portion of the frame.
One of the reasons it doesn't hold the line like a two wheeler is the rear wheel is reacting to the crown in the road, ie; Tail wagging the dog, Also there's no gyroscopic effect like with a two wheeler , Believe it or not if you ease up in the bars [grip] you'll get used to it. :thumbup:
My two cents worth, I have my shocks at 4 and 18 lbs. air. This works for me. as far as adjusting I was able to move the shocks to 4 without raising it. and if you want to go down you should find going down to be easy without raising it.
I think on the later Spyder's BRP started to use a better grade of medal on the adjustment rings. [cams]
Early on quite a few rings broke if Wd 40 and jacking up weren't done..
I broke one on my 08 even after using Wd 40 and jacked it up. :shocked:
