Garmin Zumo Connections?
rjgraph
Hey everyone. So i bought a used 2012 RTs came with Garmin ZUMO 660. I want to use this. I have the mount and the wireing harness. Does anyone know how to plug into the bike? The harness has a helmet plug, mic plug, usb, and a water proof 2 lead plug that looks like it would plug in under the seat. I cannot figure where it plugs in. Any help would be appreciated.garmin.jpg
I can tell you, on the F3 Limited, the wiring harness plugged in on the left side towards the rear of the gas tank. I would think if you take off the tupperware, you should be able to find where it plugs in.
Also, if you go on the BRP installation website (https://instructions.brp.com/e-instruction.html#tab=1) you can find the installation instructions.
Good luck.
The wire runs down through the middle of the handle bars on the one I had, but can possibly be done other ways. (with you sitting on the bike right side) Than wire runs down on the right side. speaker plug is near the front of gas tank right side and the double plug plugs in to the female end near the back of the gas tank right side near the passengers handle. Good luck with your project. :thumbup:
