hollybry
Interesting! So there is already a 12V outlet lead on the left side under the plastic? i will look for that. Thank you!
I did just buy a Ram Mount that attaches with an adjustable strap to the handlebars. I have not hooked it up yet, but I think it will work for my phone.
Can you tell me more about this battery pack? That sounds like an interesting alternative. Will it charge my phone and run GPS simultaneously? Where did you mount it? How did you run the wires?
All Spyder has 12v outlet lead on left side under plastic, usually zip-tied. You can use $35 brp outlet that you can install in the frunk or generic $6 outlet that you can zip tie but I don’t use any outlet in a car or bike. I use battery pack for clean electricity. Electronics and smartphone costs too much these days to feed dirty electricity.
You can use $38 ram mount that mounts behind the left or right multi-function housing (2 screws out then replace with bracket and longer bolt) and universal ram mount phone holder, both available at value accessory. I did bolt a $9 ram mount directly on the handle bar on 09 too.
Yoke ram Mount will probably fit too and that’s like $16.
Both of these take minimal mechanic’s ability. Just look for black rubber boot after you take 2 left side panels off for 12v lead.
Yoke Mount. First up to 3” so it may fit around the round part of handlebar.
