harborfreight 1500 lb motorcycle lift
My coupon is for limit 5 in the store or online and on the phone it expires 11/24/12. The code # 82949091
69.99 Lot no. 2792
Got it out of Motorcyclist magazine page 119.
Has anyone that has Seal Floorboards used this lift? I am wondering since Seal Floorboards stick out as much as they do (a good thing) if the lift can get close enough to work properly.
Yep, it worked on my RTS when I installed the Seals this morning. I first jacked up the RTS to put her on jack stands, but I was a bit nervous when I took it off the stands to let the RTS down. Just don't push the jack in too far. It should be in just far enough so the front end of the jack pads goes fully under the frame of the Spyder otherwise it would be too close for my comfort.
It won't get close enough with Seals on an RT much to my disappointment.
Stillriding, it worked fine on my RTS this morning both before and after installing the seals RT SM5 DLX version.
