If you have seen several of my posts recently you know I have not had a good few months with the Spyder. I initially took it in to have the shaft recall done. RideNow in Peoria got it in and completed in a day. I also had them look at an issue with my parking brake. This is where the SAGA starts.
Upon initial diagnosis, it showed there was a problem with the left handlebar switch. They replaced the switch and anointed it fixed. Well it wasn't. It continued to fail every so often, but not consistently. They found a pin on a connector that was suspect, so they fixed that, and again it appeared to solve the problem. Because of this they discounted the ~$800 bill 50%. So they put it on a trailer and delivered it to me (100+ miles) from the dealership. They did this as goodwill for all of the previous failed fixes.
But, while unloading my Spyder, their driver tore off my grille. So back on the trailer and back to the dealership. They ordered the new grill and got it installed. When they went to move the Spyder out of the shop, the parking brake malfunctioned again. After re-checking everything, they were at a loss as to the problem and had to get BRP involved. After several hours of troubleshooting with the mothership, it was determined that there was an intermittent short in the parking brake motor. So they replaced the motor. If they had charged me for the motor and all the hours worked, it would be another $1200. While they were moving it in and out of the shop, it seemed to have a weak battery, so they replaced the battery ($210 parts & labor).
All told, they replaced the left handlebar switch, a connector, the parking brake motor, the grille, and the battery. Because of all the trouble and delays in getting the issue resolved, they asked that I pay an additional $400 to close out the entire ordeal. So all told, I ended up paying for the handlebar switch. I thought this was a very fair deal, and will continue to use RideNow in Peoria as my dealer of choice. I will be in Phoenix in a few days for other things, and will pick up the Spyder then. So now maybe riding season is finally here for us.
