wyliec
Whew that wore me out.
Me too.
I run with every light I have , high beam everything, I wantto be seen , if the other guy does not like it, I, m sorry but I want to live. And have fun riding :thumbup:
The low beam lights do not flicker, they are NOT too bright (DOT regs), nor does the shutter bounce unless large bumps are encountered. Its the bike that moves and the demarcation line where the beam cuts off moves through the oncoming persons field of view. It makes it appear to flicker on and off like you are flashing your lights at them. If this is occurring at distances greater than about 30 yards, your headlights are adjusted too high. Lower the beam and therefore the cut off line from the shutter so that the oncoming traffic does not see the bulb when on low beam. The cut off line should stay below their field of view.
Use High beam to be seen in the daylight hours. The fogs are useless in the day time and they are cut off from view.
Based on my experience, I disagree with your explanation on operation of the low beam system.
Case in point; Last Sunday I met up with a friend on an HD. We headed out on a relatively smooth blacktop road with him in the lead. About a mile up the road he pulled onto the shoulder and stopped, He had seen my lights flashing and thought that I wanted to have him stop. I looked at my switch and it had been moved to the low beam position. I put it on high beams and we continued on. A couple of miles up the road, we stopped at a stop sign. I rode up beside him and asked him if the lights still appeared to flash. He told me that they did not. JME:dontknow:
I can ride all the way into work pass many vehicles and this is the only guy that has an issue.
SO I WOULD SAY HE IS TRYING TO BREAK MY BALLS:yikes:
I HIT THE:cus: IGNORE BUTTON THIS MORNING.
And yes i was sitting on the seat while adjusting lights. They were along ways out.According to the book they are exactly where there suppose to be.
I marked the 2 lines on the garage door and adjusted them:spyder::spyder2:
I have the BRP hid lights and get that a lot. They are so much brighter but the step up of the beam is pretty pronounced and there aim is not real high. I have the factory fog lights but don't really seem to half to use them much.
I'll have the BRP HID xenon's installed in the next week or so. Do you ryde with the highbeams on most/all of the time or just rock the lowbeams most/all of the time? (except at night when no cars around - of course that's recipe for highbeams)
Your story proves what I said exactly. Not sure what it is you are trying to say here. Putting the lights on 'high beam' raises the shutter such that the light bulb is visible from all angles and thus he did not see the lamp appear to dim. What he saw as 'flashing' was the shadow line of the shutter moving through his point of view.
