heat from right side of Spyder
ravseren
Does anyone know how to reduce the volume of heat that comes out of the right side of the 2011 Spyder? s there a block or diverter available?
Spyderpops has what you need
Harvey, Spyderpop, is a SLovers site sponsor. He has a block plate for reducing/stopping heat.
There you have it..!!
spyderpops and ISCI are the two outfits to help you out..if you have floorboards the heat is worse. I have spyderpops heat solutions and they work well..!! :thumbup:
heat right side
I have a 2010 rt and had a lot of heat on the inside of the right boot. I used a high temp heat wrap on the pipe, works great.
