Help please
SpyderJaye
Hello fellow riders. I own a 2018 Can-am spyder rt limited se6. I started an audio upgrade because I blew out a speaker in the rear. So I replaced my factory speakers with 5 1/4 kickers and 5 1/4 poll audios in the front. Then I decided to hook up a new amp to get cleaner sound quality. I could not find a plug and play wire harness to hook up to the factory, audio wiring harness. I ended up cutting the factory wiring harness that plugged into the factory amplifier. I then hooked up the amp power,ground , speaker wires and am getting no sound out of the speakers any suggestions ? Is there a signal wire from the head unit that needs to connect to the amp and what color is it?
It is dangerous to cut into the OEM wiring harness on a Spyser. The later the model, the more gremlins it can cause. BRP has gotten very tricky with their electronics. It's gotten to be "Plug & Play" or "Grieve & Pay".
