TerryTheSpyderRyder
I have a safer, easier way of doing this. Instead of removing the lower shock bolt, I remove the four fender bolts and swing the fender out of the way. Then I jack the Spyder up just enough to take the wieght off the axle. It comes out easily then (providing it isn't seized from lack of lubrication), and I roll the wheel out the back! No heavy lifting and the Spyder isnt jacked way into the air, never a good thing when using a jack on anything. And, you're never under the machine. Also, before putting the axle back in, coat it with synthetic grease per the manual. Don't use anything else and coat it from where the threads end on the shaft.
