How can I open the Turn Signal & Mirror Case without breaking something? Any thoughts?
spyderider1
I did a search and found little information so I'll post this question. My right front turn signal is out and I'm curious about how to open the case without breaking something? I know there's tabs, but I'm not sure where they're located. Any thoughts?
Check your connections first. Use a voltmeter to check your leads to confirm you're 12v to the connection point. I can't find anything on opening up your rear view mirrors. Check with Peter or BajaRon on how to do it.
You can buy an Acrobat PDF copy of the Shop Repair & Maintenance Manual online for US $24.50.
Thanks guys, I've got a service appt. next week and I was just trying to get ahead of the curve. One item to share with others; after repeated oil changes requiring the magic mirrors to be removed (6 to 7 times) the connection/plug for the turn signal failed on mine. The wires separated from the socket and so far are impossible to reconnect. So, before I make things worse, off to the service dept I go.
