How do I remove the screws on the front splash panels?
TRMary
how do I remove the plastic screws on the front splash panels? I need to remove them so an upgraded sway bar can be installed.
Are you talking on an older RT (2010 - 2019) on the panels by your knees? If that's what you're talking about, you don't remove them. They just have a "hook" on the inside that fits in a rubber grommet. Don't turn them, when you remove the panel, they just pop out. If that's not what you're talking about, then never mind!
FYI... You should always state what you ride (make, model, year) so we can better help you. Also, pictures help a lot.
Remove pins, rotate, slide aft, R/R swaybar, position splash guards. Use a #1 Phillips screwdriver gently. Then remove base of that pushpin. There is a screw, as well. They don’t have to be completely removed.
