IdahoMtnSpyder
Well-known member
I just thought about a way to check battery health without taking it to a shop to load test it. When the battery is new connect a volt meter to it. Or do it now even if it's not new. Turn the ignition on and hold the throttle wide open. This keeps it from starting. Push start and crank the engine for a few seconds (5 max according to service manual) while monitoring the battery voltage. Then occasionally, like once or twice a riding season, repeat the process. Make note of how much the battery voltage drops within the 5 second time frame. When you see it start to drop precipitously it's time to get ready to replace the battery.
