I HATE Vapor recovery (ECO) gasoline pump nozzles! Is this just "my issue" only? Anyone else? What do you do to avoid this?
I apologize for not being more explicit about my local Costco's gas pump nozzles. I learned immediately to pull the boot back to use the nozzle, but the firehose velocity of the fuel coming out of the nozzle and the total lack of finite control of the nozzle is what made me dump Costco for refueling my bike.
So, you get no spillage with this set up? Will it have any gas on the unit when you're done that you have to deal with? Most gas stations here don't have rags handy that you can wipe things off before you stow them away, so where do you put it when you're done?
I have never had any spillage with the McCuff (maybe once when the pump failed to stop!). Yes, there can be some gas on it when I'm done, but usually very little. When purchased new, a McCuff comes with a case. Mine wore out a while ago so now it just goes in a Ziploc bag which goes in the trunk. I think the fact that I'm using a plastic bag which hasn't disintegrated supports the notion that very little gas is on it when I put it away.
My typical ride uses 4-5 gallons of gas. I stick the nozzle in around 1/2" in the small opening in the tank neck and let it more or less rest there. Holding the boot back and filling to the first spit back and I am done. Only takes a short time to put that much gas in it. So I do not understand how this is a big issue. Of course, there was a time I would stand on top of a 8500 gallon tanker and fill it up, which took like 20 minutes or so, if I remember correctly 50 years later.
I just ordered the McCuff from Amazon. Both sizes to see which is better for my needs.
Hoping it's a good fix. Thanks everyone for chiming in. I'll report back which one (Sport or Twin) worked best for me.
