I just ordered BUDS w/ Megatech license.
Thanks - did you create the custom tune map or was it pre-made? I like the idea of less twist of the wrist when above 25 mph.
The PV4 is awesome. It comes with basic tunes from Dynojet, but when you buy from Fuel Moto they include custom tunes, and updates for when you add mods later.
I've collected several data logs from riding and sent them to Fuel Moto, and they tweaked the tune twice for my specific bike.
I'm happy with the current tune, until I make my next performance mod. ;)
As far as tweaking the throttle map, I had to buy access from DynoJet to unlock the tune files.
I only changed things above 40% throttle, as I didn't want to make it twitchy around town or when cruising.
I have it now so it gets to 100% requested torque at around 80% pedal, which makes it easier on the wrist to get full power.
I also lowered the cold and hot idle speeds, changing the map so it doesn't rev so high on startup, and lowers idle a bit quicker as it warms up.
I didn't go too far with that, and I haven't had any stalling or other startup problems. BRP probably has the fast idle set to warm the cat for emissions.
I asked Fuel Moto beforehand, and he said if I was only changing things like throttle and idle speed, fan on/off temps, etc, they would still continue the free tune support.
He did say if I made changes to the fuel or ignition maps, or other critical parameters, that he wouldn't be able to continue the tune.
I can understand that, as dicking around in there would make it hard for him to track changes.
Overall, I'm very happy with the PV4 as well as Fuel Moto.
Jamie and Lucas are great people. I've been using Fuel Moto since 2004, when Jamie started cutting his tuning teeth. I'll likely be buying my tuning license for my PV3 sometime this season :)
I have PV4 also with a custom tune from BLR. I’m interested in your comment about purchasing access to tune files. How do you do that and are you using a pc to make changes after that? Thanks.
Yes, I use my laptop to make changes. It's much easier to find and track changes than on the phone.
The parameters are separated into sections. Some are available free, while others require a subscription to access.
When you click on a section it will tell you if you need the subscription. IIRC, it includes a link to the website where you sign into your account and subscribe.
What is IIRC?
It will likely be in your cloud on the Power Core tuning app. Go to the C3 Tuning center and check the cloud.
I’m lost
I think I got it thanks
Got thru it all. BLR set up the C3 tune page and in doing so I can’t even look at the stock tune cause it’s password protected by him.
Who is BLR? I'd contact them for the password.
I’m lost
He probably locked it so you can't alter his tune adjustments. As long as the .stk tune file is on your PV4 as an available flash, you shouldn't have any concerns.
He probably locked it so you can't alter his tune adjustments. As long as your .stk tune file is on your PV4 as an available flash, you shouldn't have any concerns.
Sorry, but I have a fundamental problem with anyone adding passwords to software that I paid for and use on MY vehicle.
