Found his post last year but don't remember where i came from.
Scorpio I900 Motorcycle Alarm System Manual Override info:
Note: I could not find this info on the web so I'm creating this page to see if the search engines index it.
Having trouble with the manual override?? Well, here is some stuff to know.
1. The directions are completely wrong
2. The code is not determined by the flashes of the blinker!!!! I is determined by the number of times you turn the blinkers on and off
3. It is a 3 digit code only! not 4, as per the instructions.
4. You will never get the code to set or disarm if you you have light kit from
http://www.customled.com/
5. If you do not set up the override, you will have no choice but a tow truck if you lose the remote.
This info should save your butt!
Update: Just heard back from scorpio alarms. Get this!
1. THE MANUAL OVERRIDE DOES NOT WORK ON ALL BIKES!!!!!!!!
2. He tells me that it does count the flashes, BUT, if the flashes are to fast (as they are with Yamaha R1) it will only register the first flash so to set the first code to 3, you would need to cycle the left blinker on then off 3 times (whish I confirmed works). This being the case, you will always have you 4th code set to 1 on a bike with fast blinkers.
3. The manual override does not work when you have certain aftermarket blinkers installed (which was also my case ALSO). Specifically, it will not work with my customled.com tail kit. This tail kit is a must have for bike owners BTW. I simply unplugged the blinkers from it under my passenger seat and sure enough, my i900 started to recognize what I was doing which brought me to the problem I discuss in the above #2.
4. Harley at Scorpio informed me that simply unplugging the HAR-1 from the MCM will reactivate the starter and disable the alarm system (but I haven't tried that yet). It makes sense since they know that the manual override doesn't work on all bikes.
5. outside of what I mentioned here, to quote Harley, "If you are following the instructions and are not getting a code back this feature just won't work with your bike."
Scorpio Contact:
Harley Hogue [
[email protected]]
Harley Hogue
Scorpio Alarms
480 951 1109
