Anyone else had a Tour pack alarm "Rear cargo open" on 2025 F-3 Limited? Any fixes?
Stevew
Good morning all,
Has anyone had the Tour pack "Rear Cargo open” alarm come on when riding even when the lid is latched? If so did you find a fix for this?
2025 F-3 Limited
Thanks in advanced
Steve
Mine warned me of an open lid but the lid was open, so...
Have you checked the switch?
If you remove the light assembly you can see the function of the tang and the switch. If your engagement pins are aligned correctly you will not be able to open the top case when locked. If the pins are not correctly aligned you can open it when locked. If the pins are correct then you can bend the lever arm on the switch to make contact sooner as the case lid is closed and that should eliminate future false alarms.
I had to adjust that switch once after closing the top case lid "too hard" which resulted in constant "rear cargo open" warning despite being closed. The switch is held in place with a single screw which allows for it to shift out of position. I just repositioned it and tightened the screw - no need to bend the lever arm.
You also get that warning for the saddlebags on the RT I didn’t check our F3 yet but I would assume the same ??
Good morning all,
2025 F-3 Limited
Thanks in advanced
Steve
Guys, it is a fragile micro switch, only 3 things go wrong, the trunk pin is not centered on the switch actuator (metal), the actuator is bent, or the switch is broken. $18 part, instead of taking the bike apart, remove switch (1 screw) pull out wire, cut and splice into existing wires, put back new switch
