White Lightening
Two and a half weeks ago I pull the Spyder out of the garage to wash it. Start up normal, pull it out and hit the kill switch ( I always use kill switch) to shut down, engine shuts down, turn the key off and remove. Notice the cluster is still on. Put the key back in and try to turn it to the on position but it will not turn. Pull out key again, cluster remains on. Re-engage the kill switch and hit start. Starts normally without the key in the ignition and the ignition in the off position. Key is not even near the bike. Did this several more times with same result. Put my gear on, start the engine and ride to nearest dealer 7 miles away. BRP replaced with new ignition under BEST warranty. So the good is BRP covered the cost, less the $50 deductible, including a third key (I had 3). The bad is another 2&1/2 weeks without a ride. In December I was down for 3 weeks because of a bad reverse actuator. That time I had to be towed. Even though all this has been covered by warranty I am starting to loose confidence in the Spyder. Last thing I need is to be on a long trip and have another problem. I've never had a vehicle of any kind (including boats) that has been subject to so many failures and such long repair times.
