Drwerner
I installed RLS's Cat Delete this afternoon. I used a Harbor Freight Motorcycle Lift https://www.harborfreight.com/1500-lb-aluminum-atv-motorcycle-lift-63397.html - which does an awesome job. Great deal for $199! It easily balances the bike and gets the front and back wheels off the ground at the same time. I slid ramps slid under the front wheel and the back I blocked with wood. I had plenty of room underneath and the whole process took less than an hour. The top spring was a PITA, but I got it off and reinstalled with some fussing. So, overall, install was a breeze.
I installed the baffle, and the sound is nicer, but not significantly different (or louder). I then attached my Power Vision 3, paired it with my bike and downloaded tunes. There were only 2. A stock one and the following: Stock exhaust Stock intake Altered DBW table Altered target AFR table Altered timing table Lowered fan temps Raised rev limit +300rpm Raised speed limits - I was honestly hoping for more. At least one that would map top the exhaust change. I am hoping more are to come.
RLS was great to work with and very responsive to my questions. I saved some weight, hopefully some heat and am anxious to see if there is a noticeable difference in how the bike performs. I do not expect it to knock my socks off, but any gains are welcome and the closer I can get to the 2-wheel bikes I am used to (BMW GSA) in terms of acceleration, awesome!
:thumbup: .
:thumbup: .
