Is an OEM backrest the best on a 2020 RT Limited
Carjones
Just pulled the pin-pending delivery on a 2020 RTL! It doesn't have a backrest, and I was looking on eBay. Does anyone have experience or suggestions on OEM vs. aftermarket?
Thanks,
Bob
I had the OEM BRP backrest but found it uncomfortable. I then purchased the Utopia backrest from ValueAccessories.com , a aftermarket Spyder accessory dealer in Ohio..
I love this backrest for the adjustablity and ease of install and removal when needed.
Check it out, you wonʼt be sorry
Artie
I wear an Air Bag and/or a jacket with a proper back protector. I could not get the OEM backrest adjusted far enough back to get comfortable.
I have the OEM backrest on my S2S because it came with it and I find it perfectly comfortable. I had the Utopia on my GL1100 Goldwing and it was perfectly fine.
If I were to buy one now, it would be the Utopia, because it presents a flat surface as opposed to a curved one. I had a friend who had a Corbin backrest on his Goldwing and the curve in the backrest was so severe that he couldn't use it. He even tried to straighten it with a hammer to no avail. He ended up not being able to use it.
I think most folks find the curve to be what causes the backrest to be uncomfortable for them.
I did find this on FB Marketplace-OEM (used) for 2020-up. The seller says an install kit will run about $50. Any ideas on this kit?
I couldn't find a separate installation kit.
I did find the installation instructions
Which has a list of the parts:
ITEM DESCRIPTION Part number QTY
P1 Removable Driver Backrest Not available separately 1
P2 Slider 708001678 1
P3 Latch Rod 708003188 1
P4 M6 X 1 Panel Nut 250000048 1
P5 M6 X 20 Flanged Hex. Screw 210262050 1
So you'd need the Slider, Latch Rod, Panel Nut, and Flanged Hex. Screw. I did a quick parts search:
Slider - US $23.99
Latch Rod - US $19.49
Panel Nut - looks like the part number has been superseded by #250100198 - US $2.95
Flanged Hex. Screw - $2.95
That's a total of US $49.38, so yes, about $50, but not in a single "kit".
I used https://www.canampartshouse.com/ to look up the parts, but if you take the list to your local dealer they should be able to order the parts for you.
View attachment 252414 - View attachment 252415 - View attachment 252416
In the past, members here have had great difficulty sourcing the attachment parts/install kit (search is yoyr friend! ;))- and unless it's changed recently, BRP DO NOT sell them without the backrest. :rolleyes:
So buying an OEM backrest alone, without the attachment components, is very risky, usually (always?) a waste of money! You'll likely end up with a useless wall ornament! 😖
Go On, just buy the Damn OEM Backrest Kit! You know you want to!! :LOL:
