Is anyone else having Issues logging on?
SNOOPY
Probably know this already, but having issues w pages loading etc. If I log out everything here works great. Being I run a couple car forums I know in the controls how certain things can be done to slow down or control users. Also posting this because it won’t let me contact any Admin, also a switch that can be turned off. If a forum issue I get it, but haven’t seen anyone post about issues. So wondering what is going on and why?
I had that problem. Turn off your VPN or have it not to be used for this site. Clear your cache and reset your browser. That is what worked for me.
I have had this issue in the past. Ended up be a problem with the router/modem. Provider had sent out a update to the modem, and for some reason the update did not install correctly, causing random issues. Tech came and connected directly to the modem and pushed the update. It took a couple tries for him to get it to take. Since he had so much trouble with the update, he ordered a new modem, and installed it a few days later. No more issues after that.
So, if you have not unplugged the modem and plugged it back in, so it restarts, you might try that.
I can try that, but why when I’m logged out I can go through threads on the forum pretty quick. Once I log in it could take up to 5 mins to load one page. And no other website I’m on has this issue.
