Is anyone else Running out of fuel like this?
redneck28871
2021 F3S with 13,500 miles. The last few times my dash says 55-60 miles left till I need to refill, it seems to run out of fuel. Once I coast to side of road, it will start right back up, then I make a mad dash for fuel. Does anybody else hear of this? Once filled, it runs fine again.
If I were you, now you know that number, I would stop or look for gas when it's close to 80! I would use the milage off my trip set to start with, then after you know your MPG, use the trip meter to safely set a set milage to gas from. Like Andy said, you should not bring your gas down to the point the the Spyder is shutting down, that miles till empty has too many variables in it, and it can leave you in a hard spot! Good Luck!!! I look for gas whenever my gauge drops to two bars and turns red!
I'll agree with the previous comments.
The miles to empty number is not reality based, in my experience.
I look for gas when the bars turn red as well. Though I've yet to put more than 5 gallons into what is supposed to be a 7 gallon tank. That theoretically leaves me with around 78 miles to empty, depending on conditions.
Frankly, I don't trust anything on the Spyder dashboard.
