Allright, let's say that a new float charger is recommended. I see NOCO Genius chargers (with desulfinating circuit) for sale but are rated anywhere from 1 to 10 amps. Which one is appropriate for a Can-Am battery? They seem to be all out of stock on the NOCO website. My local Cabela's has 5 amp chargers in stock. Would that be overkill?
In the meantime, I think I will remove the battery, charge it overnight, and load-test it in the morning.
But wait! What do I charge it with? My battery tender, or my automotive charger that I use to charge car batteries? I don't want this thing to explode on my work bench overnight! I have been using a Schumacher 1.5 amp battery charger/maintainer with float mode monitoring. Will the battery hooked up to this provide a full charge by morning?
As Ron suggested, I'd go with a 2 amp charger if you can, maybe your automotive charger, especially if it's got a small/motorcycle battery setting &/or an AGM setting on it. Ideally, you'd do
this bit, but then re-install the battery in the Spyder and let it sit for
at least the next day before repeating the load test and seeing what the results from that 'check the voltage while cranking' thing say.
It's important that you start with your battery fully/properly charged before load testing it, but as others have mentioned, taking it straight off the charger/tender and then testing it, or worse, starting it up and riding away, can actually give you a false sense of security and leave you thinking your battery is still OK when it was really just the surface charge that let you get started, and you still might risk your battery failing to be able to start your Spyder once you get a long way from home/help/recovery!
As for 'Needing' to replace your battery right now, that
might not be
essential, altho seeing 11.1 volts while cranking definitely suggests your battery is on its way out -
but how much are you prepared to risk?
If you
ONLY ride to places where there's support and access to replacement batteries, and you
NEVER stop out in the boondocks, then maybe you can risk sticking with the battery you've got, knowing that it's 'less than optimal', but it's still cranking OK, and if it does fail on you, you'll be likely to be able to replace it and continue on &/or get home, then maybe...
But remember, once these batteries
DO fail (and the signs are that yours is heading that way!) then there's the chance that no amount of 'jumping' will get you going again, and we KNOW from the many reports here (and for some of us, thru somewhat difficult personal experience!
) that the next likely result of this 'dying battery' thing you're now experiencing the very first signs of will likely be a cascade of weird errors, inexplicable codes, VSS Interventions, &/or Limp Home Modes, so if you're prepared to risk it, then maybe you can continue on for a while, maybe even a fair while -
but it IS an increasing risk the longer you persist with that dying battery, are you prepared to take that risk??
Over to you! Good Luck.
