Is there a Third Brake Light I can install on F3T Luggage Rack?
Chief-J
Good morning. I have a 2023 Can Am Spyder F3T with a Luggage rack. Is there a third brake light out there that I can install on the luggage rack?
Thank you, and safe riding.
That looks like a generic stop light from Amazon or eBay could work.
My F3S has a brake light controller under the seat that combines brake and turn signals for the multi-function taillights.
The input of that module has separate brake and turn signals where you can pick up a brake only source.
I added a led combo running/brake/signal light to the rack on my F3. I bought it from Admore lighting. Pleased with it. Sequential signals flash amber, otherwise solid red.
I have a 2016 F3T with a LaMonster pack rack. I installed a Running Light / Brake light.
Available from Amazon.
https://www.amazon.com/dp/B09K78MYL...=35O8CXFZFZGOP&psc=0&ref_=abl_lv_ov_lig_dp_it
OTOHANS AUTOMOTIVE LED Rear Tail Brake Light With Nuts Washers Compatible with 50cc 70CC 90cc 110cc 125cc Taotao SunL JCL Coolster Roketa Kazuma Chinese ATVs Moped Quad 4
Rear Light Wiring F3T
Which one for just the Brake Light. I want to connect to the brake light on my F3-T. The F3-T uses turn/brake for the same wire. Sooo how do I hook up just for the brake lights only?
In those plugs, the wires are thus:
Right Signal = BLACK/YELLOW
Left Signal = GREY/PINK
Running Lights = WHITE
Brake Light = ORANGE
BLACK = ground
backup = PINK/BEIGE
