bruiser
Most of you know Bruisersbaby drives a 2010 RTS SM5. Lately she's been experiencing this icon (!) on the dash. This is the same icon used for the parking brake but it shows up on the center main display where a code would show, and sometimes the parking brake indicator will flash at the same time. It will go away after a few seconds. She first had it last Saturday on a charity ride. We had a 20 minute stop and when she started the Spyder up for the next leg this icon showed up. As soon as we started moving it went away. There are no codes. Brakes work good, stop on a dime and give you 9 cents change. Brake fluid is where it's supposed to be, no leaks. Just had it serviced and the dealer said everything was good. It was hooked to BUDS for the service. This is an intermittant occurrence. Today we were sitting in line waiting to get gas, her foot was on the brake and the icon started flashing for a few seconds but then went out. The only thing the OM shows is VSS or brake failure/low fluid. Doesn't happen while driving. So, has anyone else seen this?? I'm going to check the wheel sensors to be sure they're tight. And this did start before we had it service. Any ideas???
